  • Replies 1k
Posted Images
nope, they are pretty boring & i'll be in brisbane
Might go. Last one was a bit boring though.
phil- you doing any more tuning tonight?
Nah not tonight. Finished off most of Pav's S15 last night. Just going to go over the whole tune one more time to make sure everything is safe. Then I can grab the wideband for my car and finish it off.
I want my AEM wideband kit to show up so i can head out for a play with mine
I'll try and remember to ask everyone if there keen for a road trip to townsville. When my GF gets her new Polo GTI we want to go to Townsville for a weekend so that might be a good time, even if my cars not there
how has that been going? i've been following his thread on NS, i think you need to invest in a kmon and do a tuning course :whistling: and start making some $$$$.
i'll give you a call later to come & get that dvd.
Yeah most of the tuning is done on it. I havn't really seen his thread (got a link?). Will probably go out one more time and it will pretty much be done. A tuning course would be great just to learn all the little tricks that you can't really pick up on by yourself. Like for example getting a car with a Power FC to idle properly seems near impossible. There is simply bugger all settings for idle and it may be perfect one day but then crap the next.
Also I find the hardest thing about tuning a car is not the actual tuning itself, but the damn troubleshooting of a problem. I completely understand why workshops love tuning brand new Holden and Fords. All the parts are brand new and there is simply nothing wrong with the car. With 15-20 year old cars, gone through 4 different owners with parts ripped off here and there just leads to so many problems that take ages to narrowdown.
I will get a kmon eventually because I want to hard wire it into my car so it pulls timing upon detonation. Would be good to use on Power FCs aswell because I don't really trust those factory knock sensors.
Hey Phil what are you able to tune? Are you able to tune a nistune?
Havn't used Nistune yet. But I hadn't used a Power FC until two weeks ago and picked that up fairly quickly so don't see why Nistune would be any harder.
The guy who does my tuning is really good for this
Playing with timing and fuel he got mine from hunting randomly to running perfect at idle all day every day. Will be one of the things I quiz him about when we have a go at my car with the next mod I have planned
I need this fixed in mine again, I think cause of the lightweight flywheel its a bit funny at idle at times. I can see how that would be the case, taking a few kilos of rotating mass when the engine is at its laziest point
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
