I've been considering getting the HID R33 headlights, but they go for a pretty penny here in Japan. found some new in the box for 1600 USD. not worth it at all. that's my Tomei Oil Pump, or something else useable.
Since I'm typing- updates today. Replaced starter, old one said goodbye over the weekend filming that video. That is the most pain in the ass starter I've ever had to replace, took me over 2 hours of pleading with god to get the top bolt off. Also removed the sound deadening that was cemented to the floor pans and such. On the prowl for a roll cage, interior sprucing up after that.
pffft wow! no shit that looks tuff with the new wheels 30profile thats brave ahah, love that last photo too!
Thanks mate. These are probably going to be my cruising wheel/tire combo, as it's a terrible set up for the track. probably will opt for the more standard 18"/35 series on the track.
Oh.... that last photo made me all tingly inside (DOF shot)... Hires plz? :)
here ya go, it's 28 megapixels though.
also, completely removed the sound deadening that is cemented to the floor panels. Use a pneumatic chisel and bulldozed it in just over an hour. Screw the fancy dry ice shit. haha, this way cost me free 99. And to celebrate here's a weight update.
Weight update...
Removed rear seat and rear seat safety belts for 31 pound/14.1kg reduction.
Stock Trunk Carpeting - 11.5lbs/5.2kg
Stock Floor Mats - 13.0lbs/5.9kg!!
Stock Jack/Tire Iron - 4.5lbs/2.05kg
Stock Spare Tire - 34.4LBSSSS/15.6kg
Nissan Air Purifier,sound deadening behind back seat, car jack - 9 lbs/4.1kg
metal plate behind the back seat - 6.4 pounds/2.9kg
Stock suspension 57.8lbs/26.3kg and HKS Hipermax 47.0/32.3kg - 10.8lbs/6kg net loss
door panels 14lbs/6.35kg
carpet and various pieces of plastic 16.2/7.3kg
Center console 7.6lbs/3.5kg
passenger seat 34lbs/15.4kg (with rail attached)
Difference in test pipe/cat 6lbs/2.7kg
new seat/rail vs old seat/rail 5lbs/2.3kg
dash stripped to shell - 3lbs/1.36kg
difference in exhausts 24.2lbs/11kg
all sound deadening 12lbs/5.5kg
242.6 pounds/110.3kgs
Stock R33 GT-R 3388lbs/1540kg
so I'm at 3145.4lbs/1429.7kgs. Still heavy! Still to come out. Rear windshield wiper assembly, HICAS, switch to CF Driveshaft, stock exaust manis, outlet pipes and downpipes.. to be replaced with SS and titanium respectively, and more!
Ive been going through this thread and im frickin loving the work mate,thats real talent.It'l be the ultimate test for a permanent marker lol
Just imagine if it was in fluoro sharpie haha thatd be sick.
rb30 huh? OS Giken sells an rb315 kit to up your 26 displacement to 3.15L
http://www.osgiken.co.jp/pro_spec/rb30kit.html
Nice work btw; love this thread.
sounds cool, but for almost 20,000 USD, I can buy an insane engine already done up vice the OS Giken stroker kit :D
I'd like to thank Fast Car Magazine! Maybe when the car is done, they will be interested in a bigger spread!
Build is on hiatus until after I purchase Allison an engagement ring. Shhhhhh!
polished the headlights, and removed the A/C radiator/fan. compressor is next but i didnt go to the garage today.
the radiator and fan weighed 15lbs/6.8kgs
Weight update...
radiator and fan 15lbs/6.8kgs
249.4 pounds/117.1kgs
Lost Birds R33 3130.4lbs/1422.9kgs.
Edited by istdercollen
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
