Hey guys, this is my first post so hello. I thought I'd join up on this site and get some good GTR info as well as post up the bits I have here and there. Moving on then. So here's my little paint project. Originally when I took delivery of the car, the front bumper had some slight damage on it. I was just going to repaint it silver, but somewhere along the way, I was asked by a close friend if they could try their hand at it. I knew this only meant things would get out of hand but I said okay. The artwork is by Allison La Valley of Lost Birds Art Studio (Portland, OR, USA) The car is in Misawa, Japan, where so far about 30 hours have gone into this. The plan is to finish the whole car by the end of February, so that will leave me time to build up the engine, etc before racing starts. I know some are going to hate that I allowed this, but remember it's just a car and as a matter of fact, there are 10s of 1,000s more just like it. Updates as they come!
pictures of the work so far.
Passenger Side Skirt
Driver Sideskirt Started
mirrors
Rear
Front
The work goes on.....
its not what i'm into mate,but regardless,good on you for being original.this is where innovation and trends start.it looks good,just not for me.keep up the good work.
  • 1 month later...
New engine is in. New suspension is in (JIC FLT-TARs), new seats (Sparco R2s), some other top secret Lost Birds stuff too.
Overly dramatic teaser video I was working on.
Edited by istdercollen
btw how's driving on the streets with those seats? the head supports looks like theyd limit your peripheral vision quite a bit
It's not that bad, your head isn't buried in there like you think since they are designed specifically with a helmet in mind. but they are illegal here for road use. The cops are too polite to give you a ticket for something like that though, so the world keeps turning. It will not pass inspection, however.
  • 6 months later...
Back from the dead. It's been hellish here after the earthquake and f*kushima. Everything is slowly getting back to normal, although the radioactive cloud over everyone's head is still a concern. The car was stuck in Tokyo for over a month after the disaster here, parked in an open lot that was unguarded and uncovered. The car was packed full with suspension bits, a Nismo twin plate clutch, Sparco seats that were still not installed, etc. When I came back it was covered in yellow goo, but otherwise untouched. I had to drive through f*kushima Prefecture, and the highway runs about 30km away from the nuclear plant. I felt sick the entire time. Pulling into rest stops, the only other travelers were fire fighters and rescue crews, very surreal to be there as it was happening.
Anyway, more parts on order for the November 6th Super Autobacs Time Attack at Nango Raceway in Aomori. New clutch is going in, some new lug nuts to look fly, Takata harnesses, and in a few days, Stoptech 355mm brakes at all four corners are being ordered. Should be fun! Also, I entered into a car show and pulled 1st place out of it, with a $200 prize. The show was more to raise money for relief efforts around here, so I just threw it in the donation tray afterwards. Anyway, enough talking! Back home in the garage!
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
