Steve: General clean up. :)
Matt, Any normal person would've thought you were trying to put a rod through the side of the block and the amount of black smoke you were putting out would be enough to make Bob Brown piss blood for a week!
  • Replies 177
Posted Images
The black smoke was because I kept mashing the hard cut limiter... The puffs of it yeah?
I was hitting soft cut, which cuts every second cylinder till I back off, then if I reach a certain rev, it cuts all ignition... hence flames + black smoke... LOL
And yeah, that motor copped some abuse... Maybe why it now rattles... LOL
Yeah All day rev limiter+lack of bottom end oil pressure=RATTLES!!! cost 1 motor
It had oil pressure... Just that the turbo let it all out... :)
LOL
I was there for fun.. Not to restrain myself... ROFL
Nah mate it's just the family of woodpeckers that moved in haha
who cares, 10points for effort, rb30's are still easy enough to get your hands on if you're happy running a stock one
Pics are up kids. :)
http://smg.photobucket.com/albums/v282/Xmetal/SAUTexikhana/
Knock yourselves out.
Did you get any more of my xr6? was hoping you might have got an action shot but i guess you cant be everywhere at once.
I'd rather spend 100 to 600 every 4 or so events, drive it as hard as possible, rather then 10 000 now, and being scared I'll break it. I'd curl up and die if I spent 10k then broke it with in 2 years
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
