2010 Sau Vic Renewal Bbq / Dyno Day - Sat 27 Feb @ Re Customs
  • Replies 160
I have an update for you all - THERE WILL BE PRIZES FOR MEMBERS!!! :thumbsup:
Most power RWD
Most power AWD
and each member will be entitled to vote in a Guess the KW's competition, with the closest the winner
The winner of each of the above will receive a $50 Supercheap Auto voucher curtosy of SAU-Vic.
(You MUST be a current SAU Vic member or sign up on the day to be eligable for prizes)
I have an update for you all - THERE WILL BE PRIZES FOR MEMBERS!!! :)
Most power RWD
Most power AWD
Hey Bec
can you bring me the trophy that i havnt picked up yet
will be there 100% on the day
This will prob be one of my few but fantical SAU-Vic appearances for 2010.
Hopefully someone will remind me closer to the date. Would be interesting to see what the 135i makes on the dyno. If it makes 50% of what the GTR made, I'll be mildly impressed.
It's 4 days away :)
Looks like I won't be the first one there anymore, as work hours has changed, but gonna come down in the afternoon :)
Still deciding on the 3 year renewal :P
Oh and if anyone wanna buy some 3M carbon fibre vinyl on the day, lemme know, I'll bring some down haha
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
