Hi all,
Before you say "use the search button" I've searched and found some conflicting advice; I read that R33 fits, and R34 fits?
I've contacted a Natrad dealer here in SA but it's been a couple of days now and nobody seems to know anything. JustJap have got alloy radiators for a good price but no autos.
Could you help by filling in the table... I'll start with what I "know" from reading the posts here... Obviously the manuals should suit their manual equivalent
Series 1 auto = R33 auto radiator, stagea fan shroud will bolt back on?
Series 2 auto = (R33 or R34 auto radiator)? stagea fan shroud will bolt back on?
https://www.sau.com.au/forums/topic/307026-which-radiator-fits/
ive fitted KOYO 53mm R34 GTT radiator, no problem. Didnt worry about auto radiator, no need, slight mod to side of factory shroud.
how much did u pay?
i just got the just jap 40mm one for $365 inc postage, just wondering if i could have gotten something better for the price
That's great stuff, thanks guys. So we could say that R34 fits S2, with slight modification to factory fan shroud? Could you tell us what you had to do to the fan shroud exactly (like cut some off, or reposition the bolt holes etc?)
Well, looks like it's no good. After lots of research and phone calls, I can't find:
a) anything alloy with the auto trans cooler
b) anything to suit R33 or R34 with the auto trans cooler which is thicker than 16mm
So it looks like I have to ditch the auto trans loop and put up with the longer time to warm-up. Just have to drive it harder in lower gears or something :blink: because the only option I have found is a custom-made alloy job with trans cooler for over $900. I suppose I should be grateful for that price though really since a genuine Nissan job is over $1,000 and that's only 16mm thick and has plastic end tanks!
One more question guys... are R33/R34 top & bottom radiator hoses the same? And which one suits Series 2 Stagea? :| I've FAST'ed for ages and they look different to R34 skyline... but I couldn't find a VIN for a turbo, which may be the same...?
Dave get them to check as there is a Radiator that`s same as Stagea i did chat to my guy here he found then ,+ it was thicker then stock on in mine ,as i toke him mine & one from 32gtst he looked & found them all in his BOOK ADRAD so get them to look harder & i think Price was about $450 & that was for Auto ok ,I will try to find out some detail`s sunday from him ok ,cheer`s Chuckie .
Thanks Skidkid and Chuckie; yes I called the Adrad distributor and he was good enough to search for me, spent some time on the phone to him, however he didn't know about anything for stagea and I suggested 33 or 34, but we only managed to come up with NIS068PACAK which has the plastic end tanks and is only 16mm thick.
Oh, and a price from a dealer was around the $550 mark.
I guess if I actually took my radiator in they might be able to find something. 1" (25mm) is thicker than 16mm too so I might check that one out.
Hi Dave ,We did find TOP TANK ,but no bottom tank ,as it`s TOPTANK that give`s up first ,i have talked to my Rad man this morning i shall meet him in week & get all DETAIL`S again & POST THEM UP ok ,but i know that the one we found was 25mm thick so that will be much better then all current one`s ,cheer`s Chuckie.
Cheers Chuckie, I think that is the go; I will take the radiator to the radiator place Monday afternoon and try to get hold of this 25mm core radiator that is a direct replacement; I am now armed with the Jayrad part number just in case they don't know what fits :happy:
As you say, 25mm is better than 16mm. And it is less than the 16mm Nat/Adrad replacement.
Buy a R33 ebay 40mm special for $200(delivered) and fit a trans oil cooler from supercheap $50.
If it ever leaks, just TIG it up!!!
lol OH to have a TIG welder in the garage... and the experience to use it without blowing holes in the work. Unfortunately I already have a good trans cooler (the stock one) but I need a trans *warmer* :) Funnily enough this is foreign to all of the radiator experts I have talked to... maybe it is true what they say, take your job to an 'expert'. And the trans expert says I need a trans warmer...
Hmm yeah I guess it's pretty hot in Queensland :)
Anybody know which radiator hoses (top & bottom) fit for us series 2 guys, by the way?
...and are R33/R34/GTR hoses the same?
im gonna go with r33 gtst, same chasis same motor, if you get gtr stuff it may be different cos of the awesomeness of the rb26's
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
