And ditto again, Mine gets taken off more than a honeymooners undies and in 3 years there is not one sign of slop or play in the system.
These units that tuner group are promoting might be better off pedalled at the rich porka dudes etc. For us mere mortals the D1 is a damn fine piece of durable easy to use kit.
  • 4 weeks later...
  • Replies 63
Can anyone tell me what is this thing? it doesn't look like a 2 piece that can be detachable.
http://www.justjap.com/store/product.php?p...=268&page=1
If it's as good as the D1 quick release but with an added protection for theft. I think it's the best deal for the function and security compared to the expensive works bell.
Take your quick release wheel off and put that on, It meant to stop people bringing a wheel with a quick release on it and stealing your car.
I think the "expensive works bell" comment is more to do with fact that the works bell quick release hub is $319.00 where as the D1 is $89.00
Tuners Group, are they a registered trader ? they have a web site and seem to be a company ?
http://www.tunersgroup.com/
Mods ?
Try Greenline or Nengun mate, not sure if they stock D1 though.
nengun doesn't carry D1.
Been trying to contact justjap.com for the past week. I must say their service is sh*t. I can't understand how you can run an online business and not reply to your email lol.
I also tried d1specnez on ebay. the problem is that he don't carry quick release lock.
Someone has one to sell I could buy lol? I don't want to buy NRG because the review aren't that great...
Ring them!
They have also been at targa tas, so cut them a break yeah?
Hi mate,
Apologies for the delay, we have had an extremely busy couple of weeks away with Targa and while we do make the best effort to get back to every email as quickly as possible, occasionally there are delays.
There is absolutely no problem shipping to you in Canada, and I will send you a pm in just a moment with some more info.
Thanks for your patience.
Steve
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
