  • Replies 63
im yet to find someone who's designed and built their own custom kit for the 33 (i mean apart from myself...)
anyone?
i wasn't happy with the other 4 front bars i tried, so this was my final straw
You have a Veilside kit, nuff said :D
there is no comeback on earth for this.....
Whatever champs, thats you opinion, garantee my car looks better than both of your cars
no... no it doesn't...
ok ,have fun takin the piss
:P i don't like to rag on members cars.... but you ASKED for it.... that shit is f**king heinous
honestly veilside should have been named failside..
yes... yes it should have...
as long as your happy with it thats what counts..
al you crack me up!
as for this thread...top secret but as stated to many around i'd try for something different
veilside for the FAIL!! only kit they produced decent was mazda rx7 fortune kit...
shanus: was going to do custom front bar similar to yours with the evo x sort of centre piece...may come later if i get around to the super gt bodykit :sick:
back on topic, I'd take the Top Secret over the one on Car Mate one, and I'd take ANYTHING over the failside kit.
that said, I'm a huge fan of the Diana kit for the R33 GTS by Insurance. Its clean and straight, none of this skirt like stuff from Vertex, BN, URAS and the billion other knockoffs.
you need balls to pull it off though, as the kit is intended to sit a few mm off the ground.
that kit looks like a rip off of vertex/bn combined front bar is basically vertex with a larger cooler hole, side skirts look shit becuase they curve up and the rear bar is basically a BN rear bar, probaly without the spoiler wouldnt look so bad..
anyway cheers for the feedback i kinda like how my car looks to. and you if its not a few mm off the ground it will look shit no matter what kit it is. nobody wants fender gap
came out before vertex etc, so if anything they'd have gotten inspiration from it. No one except VIP style modders rock Insurance kits, so I doubt anyone in oz would have it unless it came with their car.
As for thread top secret ftw (i also have a full top secret kit)
as for vertex/bn style kits i cant stand the front / rear of them.. i'm not sure why but dare i say it.. veilside rear bar looks better then the fugly square things that stick out a mile in real life.. imo
in saying that though id still prefer the vertex style over the veilside front and sides (i actually really like the side skirts of the vertex style)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
