So the old girl needs a few dings pulled out and a respray, so I'm thinking of giving her a new colour to go along with it. The two colours that pique my interest atm are Satin Black (leave the rims grey) and Calsonic Blue (powdercoat rims white). I'm leaning towards the blue, as I've actually yet to see a good matte black job in person, and have my doubts about its longevity. How do both these paintjobs hold up? the car is (hopefully) going to be spending a bit of time at the track, so which paint would hold up better? also, i'm after rear and front diffusers, pods and side skirts; who does this stuff in Sydney? anyway here's my car for reference:
Cheers :P
https://www.sau.com.au/forums/topic/307582-paint-job-on-my-gtr/
  • Replies 57
Posted Images
I was going to say Satin Black too!
Will look nice.
As long as it is a good paint job done, it will all hold up on the track.
There a many track cars with gloss / satin paint jobs.
Calsonic Blue with White wheels or R33 GTR LM Champion Blue would look nice. (National Skyline GTR colour).
You could go White and powder coat black wheels.
Crystal White or White is the national racing colour of Japan in International Motorsport.
personally i don't like matt or satin paint jobs. they constantly look dirty.
i would have to say that out of the colours you offered to choose from, the blue and white would be my pic.
I've never seen a matte paintjob in person, so is that the issue with them? The only ones I've seen are either in photos which look spectacular, or some dipshit who's sprayed the car with a spray can.
Also, how will the blue hold up? and is Calsonic Blue an actual colour?
cheers
Go the blue! I have seen a GTiR in that colour with white Oz Racing rally wheels and it looked awesome! I would go that colour if I was going for a colour change. If you are going to go down the satin black road and you are worried about longevity of the paint, just do it yourself but be a bit different and do it in blackboard paint! if it chips of you just get the roller out and repaint :laugh:
At this point I'm pretty sold on Calsonic Blue. Engine will be coming out soon, so after welding in a rollcage I'm going to spray it inside and out. So, how would i go about getting the right colour or paint code etc.?
cheers
i've seen plenty of hotrods done it matte black and they all look bad. a mate of mine has a hilux (4wd version) done in matte red and matte black and it looks pretty average. is painted well, but the matte look just makes it look... i think dull is probably the best way to put it.
  • 5 months later...
I know this thread is a few months old, but I'm also undecided on the satin/matte finish.
My car is going to be black, no question. A good satin black job looks a LOT better than gloss black in my opinion. And the painter reckons it'll hold up just fine. HOWEVER, he has one reservation. If the car gets something on the paintwork that can't be washed off easily, you can simply polish gloss paint. He says that if you ever need to polish the satin paint, it will start to get shinier.
In other words, in a few years time you may have shiny/gloss looking sections on your satin paintwork. And that'll look stupid.
Such a pity........satin black rocks. Observe.
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
