Hands On Engine Performance Tuning Day
Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily -
Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
Welcome to SAU, looks like you've picked up a nice one! Any plans to spend more money that you have on it until you hate it?
Also I cut away the top metal that was bent as there's no way I could have gotten it level and the rust stopped. I can also see clean metal under the windscreen. So it looks like this is the extent of it. The lower metal here is also strong.
