  • Replies 122
No probs mate. Sorry i took some of my replies over the top.
Can we get back to the original topic?
If i decide to keep these, what area of cams would best suit them?
I guess my 3 options 1. Got them here and try make the most out of these. 2. Sell off and buy what was suggested or 3. Sell off and buy a single kit..
But can we stick to the topic at the moment. About te best bump stick for this set up?
What do these compare to the -10 turbos??
They would be similar but the -10's would be more efficient & produce better hp. My advice to use these on your block get some 270 cams with a lift of min 10.25 you spend money on a port job I suspect you could improve spool by 500rpm. You will need to spin the engine to 9k to get the most from these.
Dunno if i wanna go to full on on this engine. As we are thinking of building another engine up. Which would better suit these. Would these suit other engines as single? Like sr and rb 20and 25's??
Do you suffer from ADD? you have been told 10-20 times
SELL THE 2835s! not one single person EVER has said keep them, every single person has said SELL THEM
BUY -5s and build a stroker.
Once again not a single person has said go a SINGLE especially not a T04z, EVERYONE said don't use a T04z, get twins that look stock, are your cheapest option, and build a 3L rb30, also your cheapest option if you are building a motor.
end of story, stop asking the same questions and READ what has been said MULTIPLE times. If they are laggy on an rb26s they will be even laggier on an sr20,rb20,rb25, they are all smaller capacity, you do realise that capacity is one of the major factors influencing spool on a turbo yes?
Sorry I lost my patience, but there is only so much I can read. Please do us all a favour and re read this thread 2 times, every single post, twice, all your questions have been answered.
Edited by Rolls
sell, purchase GT2860-5 and drop in tomei cams, plus some cam gear pulley wheels, for under $3500 total.
Tomei procams, in/ex 270, 10.25 lift, $825 delivered for the pair - http://www.ebay.com.au/itm/Tomei-procam-camshaft-skyline-rb26-det-r34gtr-in-ex-270-/140424051691?pt=AU_Car_Parts_Accessories&hash=item20b1ecfbeb
garret GT2860-5, pair $2500 delivered, http://www.ebay.com.au/itm/GARRETT-GT2860R-5-x2-TURBO-KIT-Nissan-skyline-rb26-det-/140420140354?pt=AU_Car_Parts_Accessories&hash=item20b1b14d42
Im using basic 'no-name' brand camgear wheels in my Rb26, with Greddy street-special camshafts to suit R34 GTR (using R34 CAS), 87mm CP pistons, ported head including HKS cam springs, built bottom end for track including HKS oil pump, sump/head baffles, oil-return, Power-fc with 550cc injectors, etc. Turbo's in my case are the downfall, using stock turbos highflowed with steel wheels. Engine built to be capable of over 350rwkw, turbo's only capable of pushing the engine to perhaps a max 300rwkw. One day will upgrade to GT2860-7's. Currently response is simply awesome, with loads of torque. Running-in tune only atm.
I seriously suggest James that you match the turbo's to the engine. Too large (as is the case I feel with your 2835's) and you wont be happy with the end result. Slightly on the smaller side and you'll be very well pleased with the repsonse of the entire package. For the street -5's would be on the large side but capable of 400rwkw, -7's would be perfect and capable of up to 350rwkw.
Some interesting info. I'm just gonna sell them off and build something else. I met and had a good talk to someone that was a proprietor of a shop in adelaide most drift cars. But had some good input for me and said he'd be happy to answer/help out with anything.
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
