Went Skydiving today... 14,000ft @ Nagambie (on the was to Shepp)
Wasn't too bad - nowhere near the rush i was expecting... So thinking about doing the solo course soonish.
ANYWAY, anyone interested in going up in the next couple of months??? Could organise a few of us to head up on a Sat etc etc.
I'll probably go another tandem again just to get a better feel for it now i know whats going on etc etc.
Overall it was great fun, such a weird sensation... :down:
https://www.sau.com.au/forums/topic/309005-skydiving/
ive driven past the signs which say skydiving when i drive to shepparton - always considered it - bit too scared though :) lol
grats on the jump! if i ever work up the balls to do it lol ill send you a message :)
https://www.sau.com.au/forums/topic/309005-skydiving/#findComment-5098249
Trust me when you see other parachuting down while your waiting it really makes you want to go. And seeing that no one plowed into the ground it also a plus lol. Mind you 14000 ft is above the clouds so you fall through them :D when you out there and already start falling any fear you have dissapears. It I'd an awesome sensation even though it really hurts your cheeks lol
https://www.sau.com.au/forums/topic/309005-skydiving/#findComment-5098355
We went for my birthday last month at Mission Beach north of Townsville QLD. Ment to be the best jump site in Aus because you can see the entire reef and coastline.
Ash if it wasn't the rush you were expecting you must have balls of steel! I thought it was insane!
https://www.sau.com.au/forums/topic/309005-skydiving/#findComment-5098752
oh hell no - i hated standign on top of the eureka towers - def aint going to jump off some plane with a dude strapped to my back....
and pay for it???? wtf!
Im with emsta on this one....
https://www.sau.com.au/forums/topic/309005-skydiving/#findComment-5098829
I did the mission beach jump too, 14,000ft. Did it on a clear day so could see the whole ocean and beach. Was awesome.
The day before I jumped i was watching others skydive. One of the jumpers parachute didnt deploy and roman candled. He had to deploy the 2nd parachute which is much smaller and they both landed with a thud on the beach haha
Didnt stop me from going on my jump the next day haha
https://www.sau.com.au/forums/topic/309005-skydiving/#findComment-5098836
Ye my best mate did a jump from there or maybe Rainbow... somewhere up that north way... view was tops.
Seriously not the rush i was expecting at all. In the plane on the way up i wasn't even getting jittery about it all which was strange lol.
I was like "oh f**k" for about the first 2 seconds as we were spinning around but after that it was all sweet :)
https://www.sau.com.au/forums/topic/309005-skydiving/#findComment-5098952
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
