  • Replies 74
i am just trying to organise getting the day off work, but most probably will be getting my entry in for driver training this week. you should enter driver training too, then we can get our team wang racing stickers!!!1
hmmm will sit out for this and come watch :cool: maybe get some pointers from track gurus
I could be mistaken but I think you need to do Phillip Island to qualify for the stickers!
You are wrong.....you need to stay at the Wang to do Winton to get the stickers :P
But if you really want the stickers just contact Bec :ninja:
im going to come down to watch, will they let me in just to watch? or do i have to be participating to enter. is the front gates open or only allowed through the side gate?
i was going to bring some friends down so make sure you guys show them what skylines can do.
there were no mod rwd there on the day iirc?
but the standard rwd belongs to me now?? :)
was an awesome, day...errrr night..
had a ball!
there were quite a few blowups / failures / offs.
include marty and I.....:nyaanyaa:
so after hearing wat andrew was saying about brake temps in the first session i thought i should give the car an even longer
cooler down in the second session. though it didnt help.
brake pedal was hitting back at me, though it may have just been warped rotors....
got onto the pre grid for the 3rd run, in the dark. this is going to be cool, glowing brakes, great pics of the flames from my car.
hrm i better check those rotors.
shit im out :)
just on the outside part of the disk
but then get home :nyaanyaa:
but that is all the way through.
edit: oh they are dba 4000, so expected anyway...?
Bugger, i cracked a rotor at Calder too. Matt, what was your best at Calder? I am pretty sure between Ryan and a few others that none of mine or your times stand ay any track aymore :)
At Calder i think my best was a 1:06.4, LOL with a cracked rotor, crabbing on the road anda hot day with a pinging engine with flat spotted tyres from Dutton :) :) It was my last track day in the 32 and the reason why i stopped tracking it until i had time to go through the car and do a refurb on much of the suspension, fuel system and brakes at an expesnse its take me a few years to afford.
But fark help you all when she gets back out there :)
Bugger, i cracked a rotor at Calder too. Matt, what was your best at Calder? I am pretty sure between Ryan and a few others that none of mine or your times stand anymore :) At Calder i think my best was a 1:06.4, LOL with a cracked rotor, crabbing on the road and pinging engine :) It was my last track day in the 32 and the reason why i stopped tracking it until i had time to go through the car and do a refurb on much of the suspension, fuel system and brakes
my time still stands.. 1:05.4 back in 2006!
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
