I have looked at lots of different options for a brake upgrade and would like to know if these http://www.skylinesaustralia.com/forums/R3...sc-t303758.html will fit and what you guys think of the price?
I was looking at the K-Sport option but they seem too cheap for what they are. But then again anything with Brembo commands a real premium (350z kit) and I would really like them to fit behind my standard 17's as I have no plans to change wheels unless I can get a set of R35 rims. (I'm worse than a woman looking at shoes when it comes to wheels :cool: )
What brake upgrade are other NM35 owners using? I know R32 GTR's are being used (had them on my 180sx) and are a very cost effective option. So I would assume you could even use S15 brakes as these are 4 pot's also?
Has anyone upgraded their rear brakes? Has anyone felt the need to?
I just want to know all the options as brakes are the first thing I like to modify and getting a straight answer from suppliers is not going well.
Sorry for the long post. Thanks in advance for any help. :)
Andrew.
Yeh, im getting the 32 gtr calipers kitted at the moment, bolt spacing is the same. They just use an M14 instead of the NM's M12 I would say there are many models that will fit with a bit of persuasion. Easiest would be the 350z fronts, straight bolt up, same lines can be used.
I think the brembos are terrible for the price.
personally I run the g4/d2/ksport etc 330m rotors and they are absolutely unbeatable for the price....I have them on the race car, the stagea and the 350z....
Hi Duncan,
Did you need any modifications (brake lines, bolts etc) to fit the Ksports? The 6 pot fronts look like such good value but I'm unsure of quality as I don't know anyone using them. But as all the replacement parts are easily obtainable and brand interchangeable it really appeals.
Do you have them fitted behind 17's or 18's. I would prefer not to upgrade wheels yet, but if I have too :cool:
Thanks for the reply.
I've got 330mm under 17s. very tight fit but it depends on the wheel design as to how close it will be.
once you add up brand new pads, rotors, calipers, brake lines, the chinese kits are outstanding value. and they don't just look serious, they are...I ran 330mm g4s at targa tasmania on my gtr without any problems.
sorry, yes it was straight bolt on (32 gtr kit on a c34 stagea). for m35 I would suggest the 350z kit because the offset will be better for m series (but I guess either will work)
That wouldn't happen to be a set of K sport/G4 brakes exploding in your display pic would it? :P Nar, I've always wondered how those brakes went. Kinda figured they wouldn't be too bad considering they're brakes and would have to meet a certain criteria in quality. I've heard mixed reports about the coilovers though.
Yes the nm35 in stock form is poor on the brakes. I replaced my rotors on the front only with slotted DBA rotors. It made i big difference to the cars braking ability.
My nm35 will never see the track. So this was a simple and cost effective exercise. Aprox $200-300 mark.
Use the rest of your budget on go fast things
:devil:
can i ask where you got them? was it a fleabay jobbie or import? or other?
RS73 on SAU does group buys on DBA rotors at a great price.
But I would not recomend only doing rotors and pads if you are chasing more performance.
Even with better pads after a few hard stops the standard brakes start to fade.
The slotted rotors will assist in keeping the rotor cooler but that is is.
Cheers
andy
I dont seem to see these floating around much on the net anymore.... who still sells them... if anyone really, I think justjap sells the G4's?
yeah I haven't seen either g4 or d2 brands for a while....ksport is around the place instead. No idea why they bother rebranding them when they are all exactly the same except colour!
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
