Andy asked me to do a quick review of my Greddy intelligent informeter. (non touch)
It displays some of the info available through the OBD2 port under the drivers side kick panel and remains plugged into it. I mounted mine in the cubby hole in the pov pack "couldnt afford a tv".
It can display pie graphs, needle and numerical data of various types, of course most or the timing and injector data isn't accurate on my car as the emanage is changing it after this.
I would recommend this for logging all aspects of the car, but it is discontinued now,(replaced by the touch version) hence the cheap $290 price I paid for a new one. Touch has a lot more options too, so ive read, like resetting cel's etc. as well as a larger screen.
https://www.sau.com.au/forums/topic/309626-informeter/
  • Replies 234
Posted Images
I think it displays about 15 different things like injector duty and cool crap like that. Different cars show different data. This one displays the dtc but doesnt reset it like the touch apparently does.
https://www.sau.com.au/forums/topic/309626-informeter/#findComment-5104962
Thats exactly why I bought it. Ive pushed the motor a bit and I want info on how its handling it before I crank it further. Dont want to find the limit of these engines just yet as I havent got the funds for the 3.5 block yet. Hopefully cooling the engine helps with oil and piston temps.
Dyno day at RE customs on Saturday if I can make it, same dyno I usually run on so it should give me a good indication which way im heading with the tune.
https://www.sau.com.au/forums/topic/309626-informeter/#findComment-5106166
Do you know if the touch can display error codes/descriptions (I am presuming that one cannot)?
They both can.
that was on my "to get" list.. but a powerFC is above it atm. :blush:
Won't work with PFC, only stock ECU(or variants). PFC hand controller does a similar job.
I have one too. A touch might be crap to use when mounted behind the wheel due to lack of tacticle feel when flicking through screens?
https://www.sau.com.au/forums/topic/309626-informeter/#findComment-5108935
I'm now waiting for a non-touch version to show up from ImportMonster...
For $240 shipped the nerd within couldn't say no.
the later Itouch outputs a signal......if you have a screen in your car you would be able to hook it up.
https://www.sau.com.au/forums/topic/309626-informeter/#findComment-5110428
    • Hey guys I’m looking to buy an r32 gtr and it looks like the shop who’s done some work on the motor was done at Fujii Dynamic in Japan. Looking to find if anyone is familiar with this shop since there not much info I could find.    All I could find was the owner has passed away early 2000s and had previously owned a 1000hp r33 for drag racing.
    • GTR front looks good. If you don't like it, I'll swap you a rolling shell R33 for it. Give you a fresh base to start with.
    • soon I also prefer the old look. At least I have more clearance for wheels up front now.
    • @PranK I think a few links in the original post need fixing...
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
