  • Replies 234
Posted Images
I just got an email from my contact in Japan who can once again get me some informeter's at a very good price. (sorry Dunc & Dale)
let me know if anyone is after one?
Cheers
Andy
Hi Andy, can you PM me info on the infometer?
Thanks, Leon.
It finally showed up, in a very well traveled looking postage satchel with no padding :|
Everything looks to be in order, no damage to the box or the components.. looks like its all there and brand new. Fingers crossed theres no dramas!
I'll see if I can photograph some of the setup/install and screen options for this thread (and M35Stagea.info) :) I should really learn japanese; the manual has 91 pages of documentation for them, and 20 for us. Im pretty sure their language isnt THAT inefficient, so Im guessing they just get more details... bastards!
Got around to installing it, the missus came over and wasnt too keen on me sitting in the car for 30-45mins last night :P
Never mind, I had a good think about where would be practical for the unit and initially tried zip tying it on the right hand side of the steering wheen; that proved to be an awesome sun light reflector in to my face - so I settled for it on the left hand side.
The display itself is nice and clear, very easy to read
I used the double sided tape to mount it, wasnt possible to get it completely flush but I think it should hold
Didnt take any photos of the wiring, but I went with the Red - Orange connection, turns on and off with the car. I tucked the cables up into the opening in the panel next to the OBD plug, havent cable tied/taped back the cables flush yet but its out of the way for the time being :rofl:
Hi Dunc
Nice job.
That is the same spot I put mine. You should be able to tuck the cable up next to the main console next to the air vent.
I managed to bend my mounting pad so it sits flat on the curved surface.
Cheers
Andy
Hi Dunc
Nice job.
Cheers
Andy
I contemplated trying to bend it but figured Id probably some how break it, knowing my luck :D
Theres already a cable running down there for the fog lights, I'll sort something out eventually.. Im thinking those little square stick on patches with tiny cable ties built in; one or two of them should keep it nice and flush.
Interesting thing I was oblivious too initially, the branding on mine! RE雨宮 (RE Amemiya), as in the tuning house for rotaries. Weird. Everything was new, in box. Protective plastic film still over the screen. Who knows :)
i rekon the mishi would have fitted with some cutting
but these ones have the mounts in the wrong spot and they hold the AC condenser out 10mm away from the core so the entire unit doesnt fit in
anyway, it will be sorted with more time and money thrown at it :P
Thats about how far the condenser sits out from mine...
how did you get it to fit without cutting too much of the reo away?
bah, dont worry actually. gotta get the radiator modded anyway so ill get them to move the mounting points forward so it WILL fit
then ill just shorten the hoses on the back so they dont kink up
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
