Has anyone with an NM35 had to replace a fuse? I've just realised my interior electrics arent working (electric windows, and sun roofs specifically) - but the radio, wing mirros etc is still all fine. I'm assuming I've somehow blown a fuse over the course of the last week.
I managed to locate the fuse box, and the back cover of it has a description of them... in japanese. The wiring behind that panel for me is an absolute dogs breakfast though! I had to take the entire panel off (not just the little cat flap cover) to see the fuses! Must be for the alarm etc :cheers:
Any how, heres what I'm working with :cool: If anyone has the feintest idea which one might be something like 'electric windows' or something it'd be much appreciated!! :D
Cheers,
Dunc
https://www.sau.com.au/forums/topic/309837-m35-fuse-box/
did you accidentally short something out playing with the monitor? If you cant read it just pull everyone out one at a time and have a look at them until you find the blown one. If you have a multi meter you just go down both sides of fuses until one dosent read 12v on both sides. When you find it if it blows again you have a 12v+ touching earth somewhere. That plug from pic 2 in other post might be on the same circuit as the sunroofs.
https://www.sau.com.au/forums/topic/309837-m35-fuse-box/#findComment-5107173
That was my initial thought, short something while playing with the monitor, but I havnt connected anything up - unless I one of the screws for the mounting plate in the roof managed to pierce the plug =/
I realised the windows weren't working on my way to get the multi meter, sounds like I can put it to good use now :cheers:
https://www.sau.com.au/forums/topic/309837-m35-fuse-box/#findComment-5107187
Well I didnt use my multimeter for it simply because its too difficult to use in the footwell - my height doesnt really help make me 'nimble' either. Took out every fuse and inspected them.. all looked fine :cool: I'll see if the missus can help me translate some of the kanji tonight
Edit
Just removed the mounting plate and the windows are now working. Remote lock via the keys now seems to be on the fritz, unlocking does work though.. today perhaps isnt my day! :cheers:
Edited by Dunc
https://www.sau.com.au/forums/topic/309837-m35-fuse-box/#findComment-5107269
So with the help of the missus last night, we now have a translated version of the fuse box :P I've left it as the 'direct translation' as its more amusing that way, 'room lamp' :P it should all make some degree of sense though. Hopefully it proves to be of some use to someone else eventually :(
  • Like 1
https://www.sau.com.au/forums/topic/309837-m35-fuse-box/#findComment-5108325
So with the help of the missus last night, we now have a translated version of the fuse box :ninja: I've left it as the 'direct translation' as its more amusing that way, 'room lamp' :P it should all make some degree of sense though. Hopefully it proves to be of some use to someone else eventually :)
I'll be saving a copy, thanks :)
I'm sure it will come in handy, I'm yet to check my fusebox to see if anything was removed during compliance for any reason.
https://www.sau.com.au/forums/topic/309837-m35-fuse-box/#findComment-5108436
  • 9 months later...
How'd you go with the remote key Dunc? Might be good to let us know just in case it happens to us? :happy:
Never did work out why the remote was playing up - seemed to correct itself the next day without any interference from me; I have an alarm/immobiliser with its own lock/unlock fob which I use now, and thats been flawless :)
https://www.sau.com.au/forums/topic/309837-m35-fuse-box/#findComment-5580575
  • 2 months later...
there is no fuel computer as i far i know.. the factory ECU handles all the petrol and lpg fuel delivery :) thats whats so good about liquid injection. anyways its done now!! picking it up tomorrow morning! will post in the LPG thread my thoughts and pics tomorrow :)
Edited by Sage222
https://www.sau.com.au/forums/topic/309837-m35-fuse-box/#findComment-5666521
  • 1 year later...
Has anyone on Importing had their front screen fuse pulled out? I forgot to get it put back in and dont know wether it was the one in the engine bay or kick panel? And if so do we know which one it is on the nm35, I have an 03 Axis if that helps :)
https://www.sau.com.au/forums/topic/309837-m35-fuse-box/#findComment-6503767
  • 2 years later...
I may have a short circuit somewhere and want to locate the Fusepanel and test it with a multimeter.
Where are the panels and how do I gain access to them . Tried searching for some images
to help me but no luck.
Obviously I am not very mechanical !
thanks in-advance.
https://www.sau.com.au/forums/topic/309837-m35-fuse-box/#findComment-7406686
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
