What do you class as good prices? R33 and R34 GTR's still fetch good prices for good examples and when you see the cheaper ones you have to ask your self why, whats wrong with it.
R33 $40k to $50k
R34 $90k to $100k
R33 $40k to $50k
R34 $90k to $100k
The prices you mentioned are very reasonable. I'm not trying to find a bargain just trying to find somewhere who sells them with reasonable profit. I'm not going to give any names here but some sydney importers must be out of their minds to ask $120-140K for near standard R34 GTR and $60 for R33 GTR. Just like you said if it's way below market price it'll make you suspect the car however if it's way over the market price than it makes you suspect the dealer (read: greedy).
Are there companies that you know of other than www.j-spec.com.au and www.prestigemotorsport.com.au who import good condition R33 and R34 GTRs for reasonable prices?
I got my car through j-spec and couldn't be happier, some dealers/car yards can be greedy but some of them wear the cost of purchase, shipping, compliance etc etc and want a good profit. So a car like the following can end up on a yard for $50 to $60k http://www.j-spec.com.au/list/0050
Guys Im currently obtaining my Motor vehicle dealers license. So i have a fair bit of inside knowledge in the car game.
1. The difference between a $50k car and a $40k car is $10 k, THERE IS LITTLE OTHER DIFFERENCE IN STOCK CARS.
2. People "arrange" to have the speedos wound back to around 40 -60k as the aussie market likes cars with this amount of ks. (Theres a guy that advertises in the Sydney trading post to wind back your speedo)
3. A car with loads of extras adds only a little to the price, many dealers remove extras, such as alarms, suspension etc as a stock car sells for a fair price and there is a ready market for aftermarket gear.
4. remember when you buy from a dealer you have to be prepared to pay for part of his rent, wages, insurance, license fees, advertising and the big killer GST of 10% on imports.
The trick is look at heaps of cars add what the extras THAT YOU WANT will cost you second hand and then offer a fair price.
Remember that theres plenty out there that wanna take ya money, not many want to help you make some money.
I know a guy who bought a r33 gtr from J-spec and he also couldn't be happier.
I went through http://www.directimported.com.au/. I found Phil very good to deal with. My car hasn't arrived yet so I can't give you the final answer but so far it has been a good experience. I looked local for a bit over 6 months and was dissapointed with what was on offer so went the import my own route for better choice. Look to pay for a good grade stock 33 GTR between $40-45K for non V-spec and $45-50K for a V-spec. People will tell you they can get heaps cheaper and all the local GTRs that I looked at were cheaper but the reality is to get a good grade (4+) 33 GTR thats what you have to pay, if you want cheaper you get cheaper. Never looked at 34s a little out of my range. Good luck!
Your best to buy stock, I've been looking around as well.
And I think you could get a R34 GT-R non v-spec for around the $40,000 to $45,000 imported and all the on the road costs.
no idea about an R33 GT-R but it'd be less maybe $30,000 all up?
Right now I just did a conversion, for a 90,000 yen to aud and it is $1108.80 AUD.
I've checked that at 3 different converters and it's same at each one.
So you can get some real cheap cars, just need the time to wait for a good car at the right price.
Those prices are too goo to be true. For a decent 33 GTR at a Japan auction you will be looking for about 2 million yen all the way to 2.5 million yen for a real spanky version (stock). Even grade 1 or R still go for around 1.6 - 1.7 million. And anyone who can ship, pay duty and GST and then comply a car for around 5 -10 000? Give the name of your governmentcustoms officer and compliance workshop!
Those prices sound good for 32s and 33s not 33s and 34s.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
