Hey people,
i am putting an RB25det into my R31.
OK....
so i have the engine cranking, and fuel pumps working. i have wired everything except for the VVT.
i have two problems. fuel pump doesn't stop priming, and engine wont start.
i have wired as per wiki page, and checked it three times..... i have 12v ignition power at injectors and at plug that goes to coil packs.......
there is no AFM plugged in.
i am still questioning what series engine i have. its def a series 2 loom, but my ECU has a black sticker, so think its a series 1 ECU. no idea what my engine is, i don't know know to tell???
the engine should start with out the AFM and VVT hooked up yeah?
i haven't wired up the neutral switch, but the other plug that need to be wired for an auto to manual conversion has been done.
all this talk of ECCS relay has me really confused.
on my engine loom, i have the ECU plug, the white plug and a 4 pin relay plug. thats it.
i am guessing the 4 pin plug is where the ECCS relay goes?
or am i missing something?
Sorry for all the posts, but this is doing my head in, and i just want my car back on the road!
Any ideas please?
Cheers
Hey people,
OK....
On the coil cover (over the coilpacks) do you have a black-box towards the back? If so this is an ignitor & you have a 94' engine. If not, you have either not wired it in or have a 95' - 97' engine. If still unsure post close-up pics of coilpacks. Or someone probably has an easier way to tell... I'm half asleep!
Yes, neither of these is necessary for the car to start. Without the AFM you will be in fail-safe & without VVT you will have no mid-range but will still run
Do you mean the auto trans park/neutral switch (inhibitor switch)? If so & you are running an auto ECU, the car wont start without that.
Also if you mean the manual trans neutral switch but are still running auto ECU the same will probably apply. Inhibitor switch will stop car from starting. Someone had a similar problem a while ago...
If the relay fits into the "4-pin plug" & is next to the ECU plug, then I would be saying yes. A possible cause for your fuel pump priming non-stop (maybe...) Either that or directly earthed instead of through ECU? If you don't get any definite answers tonight post up pics of what you are unsure about...
Any ideas please?
Cheers
Let us know how you go, post pics if need be & we'll go from there. Good luck!
i am not running an igniter cos there is no where to plug it into the loom. its def a series 2 loom, but i dont know its its series 1 or 2 coil packs.....
the fuel pump did prime properly when i first wired it up. it turned on for about 5 secs, then off again. but now, for an unknown reason, it stays on....... is it a problem if its always priming?
i dont know if its an auto or manual ECU.... are they different?
the car cranks, and sounds like it wants to start! haha, i have had a problem with inhibitor switch before, and car didnt even attempt to crank.....
the fuel pump is directly earthed..... well, wire 50, which is earth on ECU, is directly earthed to body, and is same earth as fuel pump relay......
thanks guys
Would have to be (or would bloody hope...) you have series 2 coilpacks as these have the ignitor built in. So running a series 2 loom with series 1 coilpacks would not work... Did you buy the complete engine (including coilpacks, etc), loom & ECU as a package, all off the same car?
Only thing I can think of with fuel pump is a bad earth.
You are right, if inhibitor switch was the problem, it would not even crank... Wasn't paying full attention to your original post.
& come to think of it, not sure if manual & auto ECUs are different or if R33s all run same ECU & have a seperate auto-trans ECU like the RB20 R32 does.
Ok, it's fine that you have power to coils and injectors, but do the coils actually fire, and do the injectors actually inject?
And do you have the fuel lines on the right way round?
i was thinking about the fuel lines this morning... the regulator connects to the fuel tank return line yeah?
is the best way to test if injectors are injecting with noid lights?
the loom does belong to this engine, but i got it all in pieces..... so according to loom, its a series 2 engine, but its a series 1 ECU.....
thanks
Yes.
Couple of ways. Yes, use a noid light. Or use a stethoscope to listen to the injectors while the engine is cranking - you should hear them tick...tick...tick. Or remove an injector, stick it in a jar, loom connected, and watch it spray fuel as the engine cranks over.
Series 1 coils would not plug into a series 2 loom and vice versa.....so once they plug into each other u have matching coils and loom.
The difference is the ignitor is built into the coil pack on the series 2 whereas there is an external ignitor for the series one.....the ecu is the SAME
Hence the reason series 1 and 2 use the same pfc with no options to set between engines
Hey people,
OK....
Any ideas please?
Cheers
You need the ECCS relay which plugs into the 4 pin plug you mentioned. This feeds power to the CAS, AFM and some pins on the ECU. Without this you won't be going anywhere!
The fuel pump relay sounds like it is connected directly to earth (on the coil/trigger side). Consequently when the relay sees power it will switch on and stay on. The relay should be controlled via pin 18 on the ECU. It is the trigger/coil side of the replay that needs to be connected to pin 18. Assuming you use the same type of relay as the ECCS relay, the configuration should be 12V feed to pins 1 and 3 (ie connect the existing R31 fuel pump wire (white from memory)), pin 2 connected to pin 18 and pin 5 connected to earth. Pins 1 and 2 are the coil/trigger side and pins 3 and 5 are the switch side of th coil.
Hope this helps.
Edited by BH_SLO32
the fuel pump relay is connected to ECU pin 18 as the input trigger. but is earthed directly to body. rather than earthed through ECU. would that matter?
i have plugged a normal realy into the ECCS plug.
how does this ECCS relay get power? through that white plug on the engine loom?
I think you should remove that earth, and just let the ECU control it like it should.
Also, you should only plug the correct nissan relay into the socket with corresponding colour, otherwise it may not be doing what it should. Then you can eliminate the relay as a problem.
...And put the injector in a container with the loom connected?????? What about fuel pressure! lol Yeah dont try that one.
thanks for all the help guys. i cut the extra earth wire running to the ECU ground, and fuel pump primed perfectly, and car started!
happy as larry........
so, thanks again......
was blowing a heap of smoke though. looked blue/grey, but smelt like running rich..... straight out of dump though, no exhaust connect as yet.....
now just have to wire vvt, and run exhaust and cooler piping.
Nothing wrong with it. The injector holds the fuel pressure. And it only opens for a few milliseconds each revolution during "start".
there is a control unit that is under the intake plenum, that has the heater hoses running to it as well.... what is meant to plug into this unit? i cant find the corresponding plug on the engine loom.....
I think its either a purple or brown (2pin?) plug, cant remeber off the top of my head. It'll be running rich because you dont have you AFM connected, probably wont rev very well either.
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
