paul. i slipped it into 1st instead of 3rd
u managed to go from 4th gear to 1st gear by accident? Unless you managed to rev-match i find that hard to believe. Unless you were rolling at 10kmh in 4th gear and then went into 1st haha
http://www.youtube.com/watch?v=avU5onrWfYo
whats the bbcode to embed youtube on these forums?
[/video ]
okay, i didnt slip it, i smashed it, thinking it was going to go into 3rd... it made an awful grinding noise. but as soon as i realised, slipped it back into neutral.
haha the whole truth comes out, cant half truth it here :D
You still interested in doing Industrial Design.
My brother applied for monash ind Design and his friend applied for rmit ind Design.
Monash included a portfolio submission and an interview
rmit included a test which i think leads to an interview.
oh and...
yeah boyeeeeeee...
fark yehhhhhhhhhh tufffff
shit kent :D
[/video ]
haha the whole truth comes out, cant half truth it here :cool:
yep, sure am.
im thinking about doing it at swinbourne..
Rmit= test= f**k that
this years my last year of school... FUUCKKKKKKK YEAHHH!!! :(
oh and nick, twas the first lesson man! i has improved!
also: thinking about buying personalised plates to show how passionate i am to some of my sydney born mates
[sYDSUX] :)
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
