LOL i love society, I'm a hoon because i own a skyline, on my P's, and have a sub, yet i've had one speeding fine in my whole history of driving (finish p's in about 10 months) that was when i darted out my driveway (i live on nepean hwy) and got caught by a camera about 200m from my house
If you've got 10 months left on your P's you haven't been driving for that long to accumulate a lot of speeding fines :thumbsup:
Lolol how u know Gavin?
used to play a game called Live For Speed with him and Mitch
lol i just noticed i went through all the trouble of blacking out all the last names then left the first one out :thumbsup:
I started off doing it that way... now i cant be f*ked and its just quicker and easier to get people in to do it.
Theres no real diff to the autechs i dont think... other then a nice white and gold Autech Japan badge.
Those TEINS are exactly what came on mine... theyre good. But i got pulled up on them at the RWC... so now i have to find a C spanner before my meeting with VICROADS on monday.
pfffft sif rice :worship: and yes i have a legitimate version of BP ultimate
Yeah right.
Ah yeah the good old 'return back to stock' for RWC... LOL!
If you got a mechanic who will be willing to over look the coilovers, you'd be sweet. Hehe!!
All the best man and looking forward to see the pics!
Thinking of selling my '34, wonder how it'd sell on here...
Why?
You car is so nice...
Yeah right.
they dont care about the coilovers they just want them wound up for the rwc
Thanks again Juliette... once its registered tomorrow arvo i should be able to drop it back down on Tuesday afternoon so i'll bring it back during the week.
Dont suppose theres a particular drink you fancy is there? wine? vodka? or anything like that for letting me borrow them?
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
