what it set you back for wiring costs if you dont mind me asking?
ive gota get the 20v wired up, thinking of doing it myself, but its gona be a massive job haha
$400, but i'm getting a bit more done...
no heater/aircon etc, but we are using the exitsting carby lines into the fuel tank and running a hilux pump to an undercar surge tank, then my old 33 pump to the motor...
also having the loom extended to fit inside the car
Yeah I have driven my friends N/A Supra.
3lt inline 6 with a Getrag 6 speed.
I call BS. I don't remember seeing any N/A poopras that came out with getrags from factory. They all came with W58 5 speed boxes. Clunky as shit... but they take a beating, kinda like 300zx boxes I guess, all that power and weight so they gotta overengineer the bits inbetween so nothing snaps.
This says the SZ-R had a 6 speed post 96
Not really. They're just the optioned one.
SZ = NA
SZ-R = Optioned NA
RZ = TT
RZ-R = Optioned TT
I've just got the SZ with a 5 speed. Mine came with optioned turbo brakes though :P Pulls up nice.
thought all supras had at least 4 pot brakes cause they so heavy
even the older models do i think
depends, after 1996 they got the option of bigger brakes on N/A's... beofre that they were 2 pots in front and 1 pot in the rear. most often if brakes are redone on earlier models guys put turbo brakes on the front as they're easier to find.
yeah, just thought weighing what 1500 odd kg that they would put at least 4 pots on front factory even on the NA's
but they must be ok for standard if they putting the 2 pots
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
