oh man troll'd. Almost as bad as that green or purple R33 that someone linked to a while back.
hellaflush is overdone, get rims that sit IN your guards then stick flares on like cool dudes do.
alr33x you should cuddle and reacharound with Mad082 he also baaaaaaws about the "old" days in the wasteland
haha check out my front pop-down spoiler :D and you all want me to bin it to fit in a larger cooler
http://www.photoshelter.com/c/jrmphotograp...0000mvqskgMirJs
looks different
keep it
on another note
my best mates ex is coming onto me
my best mate wants me to crush her hopes n dreams 0_o
yeah he is a total queer dog, he seriously likes magnas and R33's LOL.
Hellaflush is how most lowered IRS Commodores sit you know :D
I'm soooo getting some adjustable control arms for mine so I can eliminate it!
that statement confirms you have no idea what hellaflush is.
oi gtr boy i made my e/n thread for shite like that in the wasteland check it out brah
R32 Auto Spoiler is teh sex, don't listen to the monkey, he's too hellaflush for his own good!
Rekin bash the cooler like I said :D luurves it
llama_au : i am SO jealous. 2way?
on another note
bro's before ho's. tell her you'll only ever accept her if she takes it exclusively in the pooper. if she agrees, then win, if she turns you down, you're doin well by your mate.
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
