you would be surpised how many people die in a week
we work at fawkner and keilor cemeteries mostly and yeah there are heaps of burials each week
puts things into perspective
man dont you feel a bit depressed working there?
Nah, you get used to it easily... well i have
plus my dad has always done it, 28 odd years so ive grown up with it
but just makes you see things a little differently, you just never know when your times up
nah, there was a lebo guy doing monuments (not anymore) that did heaps in the muslim part
we only did a few for muslims, but i would remember if i put a numberplate on the headstone
ahh yeah
i havnt seen it yet, dont want to!
just hate cemetarys man
wow wasteland is going off like a frog in a sock, kris why not grab a second hand one shouldnt be more then $100?
Yea I looked on eBay. Either they are series 1 clusters or they have 150,000km on the clock :( want a mines 320km speedo but can't find one :(
just got credited 40 bucks back from saving a bit on postage in japan for my rims :( good to see import monster actually credited it back to me and not just kept it, as i wouldn't of known any better :(
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
