you would be surpised how many people die in a week
we work at fawkner and keilor cemeteries mostly and yeah there are heaps of burials each week
puts things into perspective
man dont you feel a bit depressed working there?
Nah, you get used to it easily... well i have
plus my dad has always done it, 28 odd years so ive grown up with it
but just makes you see things a little differently, you just never know when your times up
nah, there was a lebo guy doing monuments (not anymore) that did heaps in the muslim part
we only did a few for muslims, but i would remember if i put a numberplate on the headstone
ahh yeah
i havnt seen it yet, dont want to!
just hate cemetarys man
wow wasteland is going off like a frog in a sock, kris why not grab a second hand one shouldnt be more then $100?
Yea I looked on eBay. Either they are series 1 clusters or they have 150,000km on the clock :( want a mines 320km speedo but can't find one :(
just got credited 40 bucks back from saving a bit on postage in japan for my rims :( good to see import monster actually credited it back to me and not just kept it, as i wouldn't of known any better :(
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
