not a fan :(
hmmm why my name and sig? If your the one that wants the car to be able to drive
the person that ownes it is only selling it
dont know.. so they can send you an EPA letter? :P
scotty-
fkn kesha. shes sick
Sounds like my ticket into ATO licenced chemicals :blink:
Ive heard Isopropyl Alcohol is used to make drugs O_o
We use it for cleaning as it doesn't leave residue and evaporates quickly. It's also a skin disinfectant :sick:
oo i got a reply from Recochem
200Ltr drum of 100% denatured industrial ethanol = $437.25 + GST
Equates to about;
$6.60 per week (3Litrs/week)
$3.00 per week (3Litrs of dimineral water/week)
$9.60 per week
Now is this worth the 30-40kw atw gain O_o
just wondering if you've accounted for the shelf life of ethanol, its reactivity to atmosphere (esp humidity from memory ethanol's eficiency decreases when left exposed to water vapour in air) and also expansion of such a large volume in your garage's ambient temperature.
no one thinks that far ahead, you learn from experience not from preventing it in the first place.
fair enough everyone likes different things. what music do you listen to?
i listen to everything, dance/trance house, rnb, retro, 80s
just not a fan of metal, classical or country
andre rieu
shits rad
hell yeh
yeah, i like justin bieber sometimes.. i have to be in the mood for it ya know
ummm just ghey
thats on a 60litre tank though
the evo only has like 47 i think and only about 40-42 is used when driving before the fuel light comes on
so works out cheaper if i do it :blink: haha
haha you would only need about 2ltrs of ethanol and 2ltrs of water for every tank of fuel.
You can also cheap out by using methylated spirits or methanol (which both are far cheaper than ethanol) and use tap water/rain water/britta filtered water
You will just need to check the nozzle from time to time to see if it hasnt built up with crap.
Good question, I know methanol absorbs moisture so its best to keep in an air tight container. I know methanol is fine being stored for long periods but havent researched into ethanol yet.
Contacted the chemical place for prices for methylated spirit and a 50/50 mix of water/meth
also pat....
$1500 = secondhand HKS2530 kit. Both Nick and I run it and get roughly 80kw boost in performance.
you just spent how much and get 30 - 40kw? and ongoing costs are how much?
yo question folks.....
how much power will an s15 make with basic bolt ons eg zorst, cooler, pod etc
cbf going on ns.com lol
Sif be happy with a few simple bolt-ons Chad :blink: Like Nick said, it's like 170rwkw tops.
Buy something pre-modified or with a forged rebuild. Save yourself money on all that shit.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
