wtf... why do cnc'd titanium parts have oxidisation marks on them? that's full homo spec.
titanium + heat = oxidisation = pretty colours
titanium + electricity = electrolysis = pretty colours
titanium + cnc machine = mirror surface in a uniform colour
in fact to make a cnc'd titanium surface go magenta/green you have to etch the surface or subject it to extreme heat, which actually distresses the material and makes it weaker. This happens naturally near welds and shit, but on a machined washer and bolt? GTFO.
Morning.
Got pulled over by the cops last night. They went over my Supra looking for a turbo, did a drug test etc.
Had me there for 15 minutes and then let me go..... without realising that I was driving manual on an auto license :P
No shit man. $117 fine. I'd have to file for bankruptcy :P
And Justin, I was.. but now I'm way too busy. I think I'll stick out the remaining 8 months.
Edited by jezza boii
yeah I doubt they'd ever pick you up on that. worst case scenario move your gear shift from 3rd to 5th only, so it lookes like you're goin from park to drive :P
yeah I'm leaning towards light blue too... it'll be a flat blue though, not metallic like that sample
eighter chrome on ultramarine blue:
or go full chrome on traffic blue:
gold on traffic blue:
liking the light blue though:
Ultramarine Blue and Traffic Blue looks quite similar and both look good.
I see you are going for the Blue car / Gold wheel or Blue car / Silver wheel look.
Either way they both looks good, but gold looks kinda "showy"...
I wanna see you "EPIC" fitment with this!
:P
http://www.skylinesaustralia.com/forums/Ve...ws-t319652.html
Very tragic...
One of the reasons I am such a hard ass about being careful on the roads, especially on cruises.
:O
i hate the media for what they said about this accident, they are always full of shit, making up there own stories. :(
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
