you have my sympathy however...
i wouldnt worry to much about it, from all my breakups and shit the next girl ive been with was better than the last
there are plenty out there and i wouldnt stress about it, its over move on enjoy life
That's true, but I didn't break up with her because she wasn't good enough or anything.
This girl was amazing. She would do anything me, she was 110% gorgeous, career planned out and a heart of gold... but I just decided that at this stage in life I don't want to be held back in any way. I want to get serious about my music and career (which could be leading places soon).
I also lost alot of friends because I was seeing her instead.
So yeah... In short, I needed the freedom. It's good so far, just a bit lonely :) Will be depressing sleeping alone and waking up without her.
Wheelspin in every gear except 5th. Yep, fun :)
Awww, I thought I was cool wheel spinning 1st 2nd and partially 3rd :) But mine is NA.. with like 125rwkw.
But hey, that power figure is huge. The power/weight ratio must be insane. How much does the car weigh?
I'm getting my new MR2 in a week or so. Weighs around 1150kg (with potential to shed more) and engine puts out 180kw stock. It's had a few mods (IC, fuel pump etc.) and running 15psi.
Should be pretty quick yeah? ;)
I'm not sure exactly, I haven't had it on a weighbridge. They weigh 1095kg stock. I'd say mine would weigh maybe 1150kg now? Just guessing.
Pretty good power to weight yeah :)
Your MR2 should be reasonably nippy.
So yeah... In short, I needed the freedom. It's good so far, just a bit lonely :banana: Will be depressing sleeping alone and waking up without her.
i think you have done the right thing mate and in time you will realise that alot more. you need to concentrate on your career alot more for a few years like i have done and it does really help.
all the best with your career, by the sounds of it you will do well. :ermm:
dyno'd the golf at a mate's shop for shiggles. 80fwkw. bahahaha. POS 8 valve 4 cyl SOHC is gutless as. Does 8.5L/100km tho.
Also, factory paint flips from puple to blue, and in the dark looks black. Thing's gonna be a kent to colourmatch.
well turns out the evo has ghey as 1/4's, as much as they look wide you cant fit a 17x9.5 +17 on the rear without it sticking out about an inch
and aint no way im flaring them to suit
why make front guards that fit wider wheels than the rear O_o
oh well have to find something in the vacinity of 17x9 +25
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
