you have my sympathy however...
i wouldnt worry to much about it, from all my breakups and shit the next girl ive been with was better than the last
there are plenty out there and i wouldnt stress about it, its over move on enjoy life
That's true, but I didn't break up with her because she wasn't good enough or anything.
This girl was amazing. She would do anything me, she was 110% gorgeous, career planned out and a heart of gold... but I just decided that at this stage in life I don't want to be held back in any way. I want to get serious about my music and career (which could be leading places soon).
I also lost alot of friends because I was seeing her instead.
So yeah... In short, I needed the freedom. It's good so far, just a bit lonely :) Will be depressing sleeping alone and waking up without her.
Wheelspin in every gear except 5th. Yep, fun :)
Awww, I thought I was cool wheel spinning 1st 2nd and partially 3rd :) But mine is NA.. with like 125rwkw.
But hey, that power figure is huge. The power/weight ratio must be insane. How much does the car weigh?
I'm getting my new MR2 in a week or so. Weighs around 1150kg (with potential to shed more) and engine puts out 180kw stock. It's had a few mods (IC, fuel pump etc.) and running 15psi.
Should be pretty quick yeah? ;)
I'm not sure exactly, I haven't had it on a weighbridge. They weigh 1095kg stock. I'd say mine would weigh maybe 1150kg now? Just guessing.
Pretty good power to weight yeah :)
Your MR2 should be reasonably nippy.
So yeah... In short, I needed the freedom. It's good so far, just a bit lonely :banana: Will be depressing sleeping alone and waking up without her.
i think you have done the right thing mate and in time you will realise that alot more. you need to concentrate on your career alot more for a few years like i have done and it does really help.
all the best with your career, by the sounds of it you will do well. :ermm:
dyno'd the golf at a mate's shop for shiggles. 80fwkw. bahahaha. POS 8 valve 4 cyl SOHC is gutless as. Does 8.5L/100km tho.
Also, factory paint flips from puple to blue, and in the dark looks black. Thing's gonna be a kent to colourmatch.
well turns out the evo has ghey as 1/4's, as much as they look wide you cant fit a 17x9.5 +17 on the rear without it sticking out about an inch
and aint no way im flaring them to suit
why make front guards that fit wider wheels than the rear O_o
oh well have to find something in the vacinity of 17x9 +25
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
