yeh thats what i saw when i looked
18x9.5 +20 rota grids
with a 20mm spacer on front its now 18x9.5 +/-0
and a 15mm spacer on rear its now 18x9.5 +5
ewww both these cars are running voltex widebodies, the rear quarter bolt on sections are shit as
:P this is the wastelandz you idjit. thread only ends when it get too big (approx 1000pgs) and funky makes a new one
i knooooooooooooooooooooo
miss the point much :)
yeh the te's are huge im diggin the bbs if u rock that stance though if u dont slam it like that will llook pox
why would u bother ? if u want stilts get some 4x2 from bunnings haha..
nah do it once do it right go baller cos most evo's fail that i see
haha they do, most run about what ive got now 8.5 +35 or 8 +38
the 9 +17 wil be a near perfect fit any wider/lower offset itll rub bad and i dont wana flare
get some adjustable coilovers and rise it higher, and then use it for what it was meant for and find some dirt tracks for some rally goodness :) .
i live on a dirt road, but i hate driving on it
i like clean cars, ive taken it down the road once it was soooo filthy afterwoods and dust was in everything.... never again
now snow.... thats a different story..... common winter :P
now snow.... thats a different story..... common winter :)
im the same, i hate hearing the stones flick up and you hear them hitting your car, it makes me cry.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
