yeh thats what i saw when i looked
18x9.5 +20 rota grids
with a 20mm spacer on front its now 18x9.5 +/-0
and a 15mm spacer on rear its now 18x9.5 +5
ewww both these cars are running voltex widebodies, the rear quarter bolt on sections are shit as
:P this is the wastelandz you idjit. thread only ends when it get too big (approx 1000pgs) and funky makes a new one
i knooooooooooooooooooooo
miss the point much :)
yeh the te's are huge im diggin the bbs if u rock that stance though if u dont slam it like that will llook pox
why would u bother ? if u want stilts get some 4x2 from bunnings haha..
nah do it once do it right go baller cos most evo's fail that i see
haha they do, most run about what ive got now 8.5 +35 or 8 +38
the 9 +17 wil be a near perfect fit any wider/lower offset itll rub bad and i dont wana flare
get some adjustable coilovers and rise it higher, and then use it for what it was meant for and find some dirt tracks for some rally goodness :) .
i live on a dirt road, but i hate driving on it
i like clean cars, ive taken it down the road once it was soooo filthy afterwoods and dust was in everything.... never again
now snow.... thats a different story..... common winter :P
now snow.... thats a different story..... common winter :)
im the same, i hate hearing the stones flick up and you hear them hitting your car, it makes me cry.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
