Will that fix an epic crunch when I shift down into 3rd? I know synchros are a standard problem for MR2s.
v6 camrys have the same boxes but with stronger internals
http://www.mx6.com/forums/fe-dohc/236060-t...box-thread.html
Lol my car is overboosting in the cold. It's funny seeing me actually max out my boost gauge. Goes past 1.5 bar. *turns boost controller down untill tune*
you sure you havent popped a vac line off?
why don't you e85 tune it while you're at it?
in other news...
Regamaster induced boner:
nice
Hmm my only conclusion is that it was tuned on a 28 deg day and now outside it's like under 10 so it's overboosting. Tune doesn't take into account the increased airflow. Then it knocks. I'll check the hoses anyway Hamish :ermm:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
