my professors (18x9.5) are just on 10kg
they aint heavy wheels
call him and tell him your a mate of mine.... then watch him drop $50 of the price like that... LIKE THAT!
whodaman?
I had about an inch on you, now with 17's its about an inch and a half lol... Lets not go there!!!!
When I get back, ive got something in store for you ;)
are you sure..? haha when u get back july or soemthing?
Oh and alex, nah im not coming tonight haha. How was/is it? same shit or...?
didnt go.. was to warm in bed haha.. think it was usual shitttt been a bit better last couple weeks but a bit more attention too it seeems :down:
Yeah cool Shan!
If they want decent resale value, then yes... Yes they do :P
that aside, regardless of ur personal opinion of gtrs, they're still an icon. Kids grow up lusting after it and staring at it. Not that they don't at other skylines but it has a rep that's hard to shake. My bf's gtst makes 280rwkw and is bright orange. And it gets a lot of attention. But my stocker 190awkw gtr gets just as much awe as his does depending on the audience. First question when people see it... 'is that a REAL gtr??'
And his car as a 34 is still 40-50k 10 odd years on.
Case closed :D
Fuck I hate it when ppl ask that!
To the untrained eye, they can't see the wider guards and the GTR badge.
What makes it worst is, I don't have the OEM Spoiler and ppl just think it is a GTS-T.
Garage Cafe Audi S5..?
why don't you e85 tune it while you're at it?
in other news...
Regamaster induced boner:
:down::D
I like!
Well it turns out that the oil light was only on because the sensor is from the gen2 NA engine.. the gen3 turbo is completely different.
That's what the previous owner told me (after I just txted him about it).
I actually checked the dipstick this time and it indicates it's full haha..
BUT there is a pool of oil under the car (probably about 100ml). Could this be because I overflowed it? I only topped it up by about 100ml
Either I have epic failed or the old owner is lying.
so originally was a gen 2 NA engine ? and now a gen 3 turbo
why the engine swap?
Well the swap was done at 220,000km when the old engine was getting a bit old.
The gen3 is a much better designed engine. And well, obviously for more power!
Gen 2 NA = 117kw
Gen 3 turbo = 180kw (stock)
Mine would probably be over 200kw. Loving the power/weight ratio :down:
Gen 2 NA = 117kw
ah yeh fair call
yeah i knew they had more power, and they dont feel so restrictive up top cause they have better cams (brother was looking at buying one)
actually when he was looking he found a gen 2 with gen 3 engine we test drove in gladstone park, was red and paint work wasnt the best best
sounds similar to the one you bought
