Try maccas... Lol
Check websites of retailers you want to apply for. Most don't use seek, they accept applications through their websites. That's how I got a job at Supercheap Auto :)
thanks, whats involved in working at supercheap?
Yeah. The gearbox/driveshaft etc. are all stock still (1990 ADM) so it looks like the best thing to do is buy a late model turbo halfcut and take the gearbox/diff off that.
Other than that the mechanic said it was a very healthy car, very straight body etc.
He couldn't believe the price I got it for :blink:
or use the camry gearset I posted earlier
you want to buy a halfcut to take the gearbox out? :blink:
bahaha.
Nah, I need the diff and all that shit too. Then sell off the rest of the halfcut and get most of the money back.
It's the best way to do it IMO.
Find me a gen 3 gearbox, driveshaft and diff then :( I bet you won't be able to. A halfcut is like $2500 and I can sell the engine alone for like $2000.
no, what you will end up with is a halfcut sitting in your garage for a bit over a year while cheap fuckers vulture shit off you. Most nga's who you think want to swap an engine will also want the gearbox and drivetrain to go with it, just like you do.
But hey, if you wanna sink 2.5k and not see the 2k you intend to make back in your pocket for a while then go nuts. If I were you, I'd spend a little extra and grab just the stuff you need.
Just sayin from experience.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
