yeh, lots of them track with them to
funks said the guy the helped developed them was a racing driver or something and they are pretty strong
only 17s in gunmetalic (nearly black) but they dont sell black 17s here atm, so if it looks shit ill get them powdercoated black
yeh will be matt black if i do them
yeah they have improved heaps in the last few years, i had rotas on the 32 they copped a beating and held up
should hopefully be a few weeks, but unsure exactly
edit: also a bonus, they have heaps more concave than te37s and are like a 1/4 of the price
nope and dont plan to
i prefer them with the spoiler, seen a few without and just reckon the shape needs the spoiler
will most likely get a carbon wing blade though
just spray it black and say its carbon
you reckon ur hoods too heavy? spray it black. say its carbon
nah if i dont like it i can resell the wing blade, if i paint it i cant
why paint the bonnet? its alloy dick jockey only have a black hood if u get carbon
:) wingless is porn
id do dirty dirty things to this car
http://fatlace.com/hellaflush/theflushness/black-magic.html
makes me want one sooooo bad
haha yeh that one looks nice, but epic fitment and epic low
the black suits having no wing
and ive lowered it now to, so looks heaps better
+1!
That's how I would like to have an EVO look like.
man i can never tell if your joking or not so i just assume you have no idea and u potentially fail at life.
yeh its fkn soo sleek its just like the ultimate cruiser.
edit u get coilovers or spring/shock combo?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
