ewww abfugly kit. kill it with fire.
That is way too wide, it just looks retarded.
The Ab Flug widebody kit for 300ZX looks pretty mint though!
Got a bit of Ferrari Sexterosser styling... LOL!
Awesome, I'll cya there. I might be a little late. Not sure yet
PM'd you.
what the f**k?
Those were my exact thoughts. The front bar doesn't look bad though. The rear is just stupidly wide and boxy.
If it only stuck out 1/4 of that width and had a smoother design then it might actually look okay.
I wonder what kind of epic spacers the guy had on them wheels ;)
one of the smaller cult followings in japan's extreme styles is the Dodge Van scene...
ECO Sucks! No Hentai Dodge Van... no life!
Now that's a gangster fucking motto if I ever saw one.
Hentai Version..?!
A perverted van.
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
