you're choosing to get 17" wheels (over 18" that you want) so that you can afford coilovers as well right now?
just buy the coilovers now, save a little more, then buy the 18". your car will roll just fine with the wheels its got on right now.
nah i liek the 17s to
ill get coilovers later on, but it needed low so i chucked in the s-techs for now
yeah... that's gonna happen. :)
my 32 was low with the coilovers, if i get them so will the evo
i'm skeptical of your definition of low. have you ever needed a sump guard for any of your cars?
my car is at nunawading getting complianced at import factory and i want to check it out so bad lol but cant, stupid work :banana:
import factory doesnt have the same dodgys running it as kamikaze does it?
oh so that was your car I was checkin out. sweet car.
had I known I'd have rubbed one out in the back seat as a congratulatory present.
thanks mate. well you can always do it another day :banana: .
does it look clean in person? ill have to see if the guys can take a few more pics of it for me to fap to lol. i dont think ill be able to check it out any time soon :banana:
Your way too scared alex.... driving around in that flashy car whinging about money, that can't be right haha
Work VS-XX 18X10 and 18x11 :banana: then ill show some respect :banana:
haha nah its not the cost but i gotta get rid of it in a year or less for tax purposes so dont wana go droppina bomb on it for such a short space of time.
prefer varianza to vs-xx
haha well not that low, was like 50mm at the exhaust
hopefully you dont drive your evo like this nick lol
haha seen that before
and nah wont wreck it :banana:
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
