I don't... we have a guy that does paint and panel at the shop, Shane. It's all he gets paid to do. He's currently finishing off all the outstanding jobs atm... including CR34M :kiss:
Lol dunno why your winking, i know whats in that car lol
haha nah im a shy kent.
lol @ the cat gave me an epic chuckle.
ps u break 300kw yet?
Nuh not yet mate. Have to organise cat removal at exhaust shop and then take it to Femno for the tune. Hopefully be done in 2-3 weeks
you mean "HBollywood"? Got sold. lol the guy was convinced when we showed him the pamela anderson sextape and pointed out that it was the same boat in it?
last time i saw it on ebay, price was a steal
fkn lol
Edited by GTR-boy
ehh not gona go anyway.
f**k dressing like a northern suburb leb and blowing a shitload of cash..
i needa pay for paint and new rims
cars coming up a treat, fitment is pretty exceptional
dress code is sneakers, no collar shirt and jeans apparently
I don't... we have a guy that does paint and panel at the shop, Shane. It's all he gets paid to do. He's currently finishing off all the outstanding jobs atm... including CR34M :)
Isnt Shane the one that owned that black s14 with deep dished works? (or whatever they were) ages ago? had NSW plates
in that case everyone going on friday nights gona be kicked out
their all wearing wog tappers, jeans and collared shirts
same shit so why wouldnt they get in?
except for shirts, but it wont matter... u gota be leb
Niggaroj got quoted 10k by micolour for his r33 in the standard r33 black. now that woulod be quality
lol was so hard not to laugh. he was talking bout engine left in, doorjambs and boot done. new rubbers and all that shit. i only had front end damage
you'd be mad to do that unless its a fk off show car nobody needs a 10k paint job on a daily car. Especially when the car is worth 10k at best
werd. the car is worth a grand or two less. so i went to dt and got the bare minimum job done for 950
lol walked past that place after spice market, got knocked back because I was overdressed O_o
I guess you gotta dress like a derro to get into wahwah so thats my review haha
lol have had that happen to me as well
fuuuuuuuu its been like 2 weeks without the car.
Getting the itch, will still take an extra week until the bloody injectors arrive + installing
Have to drive the damn Hyundai Getz -__-
Anyone have a decal printer? I want to make a sticker "Getz Stuffed" for the rear window and "Mazdarati" on the parents' mazda :)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
