20's rev higher than 25's, so they both have thier up's and down's
so say you hit full boost @ 3500 in a 25 and rev it out to 7000, that's pretty much the same as hitting full boost in a 20 @ 4500 and revving it out to 8000
i was thinking, how awesome would a 32taxi look with a GTR front
dumped on EQUIPS.. or advan Rs's
edit: where the f**k did i pull challenger from? 0.o
Edited by GTR-boy
my mate bought one... flash tune etc etc had a lil over 200 @ all 4's
he was bored with it in like 5 mins
i enjoy mine.... just want my new wheels farken :down:
Rb20's pull ?? Lol. I've driven a rb20 with a bigger turbo. Can make a cup of coffee before it spools. Worst engine in a skyline :cool: but it's strong
mine was actually pretty responsive with 225kw considering the size of turbo etc
just needs to be setup and tuned right
oh i see...
barley see any nice r32 sedans around..nicks was the nicest
in Adelaide now so we will never see it again :P
definately one of the best...
:rolleyes: i do miss it
aight. Thermo-fan controller is wired in! Wiring a bit ghetto but should last me through Saturday's drag day so I can fix it up during Sunday. Just need to program the correct temperature signals and we good to go!
It cooled from 92 degrees to 80degrees in 8 seconds whilst standing still O_o
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
