20's rev higher than 25's, so they both have thier up's and down's
so say you hit full boost @ 3500 in a 25 and rev it out to 7000, that's pretty much the same as hitting full boost in a 20 @ 4500 and revving it out to 8000
i was thinking, how awesome would a 32taxi look with a GTR front
dumped on EQUIPS.. or advan Rs's
edit: where the f**k did i pull challenger from? 0.o
Edited by GTR-boy
my mate bought one... flash tune etc etc had a lil over 200 @ all 4's
he was bored with it in like 5 mins
i enjoy mine.... just want my new wheels farken :down:
Rb20's pull ?? Lol. I've driven a rb20 with a bigger turbo. Can make a cup of coffee before it spools. Worst engine in a skyline :cool: but it's strong
mine was actually pretty responsive with 225kw considering the size of turbo etc
just needs to be setup and tuned right
oh i see...
barley see any nice r32 sedans around..nicks was the nicest
in Adelaide now so we will never see it again :P
definately one of the best...
:rolleyes: i do miss it
aight. Thermo-fan controller is wired in! Wiring a bit ghetto but should last me through Saturday's drag day so I can fix it up during Sunday. Just need to program the correct temperature signals and we good to go!
It cooled from 92 degrees to 80degrees in 8 seconds whilst standing still O_o
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
