these getrag gearboxes are noisy buggers, they seem to shift more smoother the harder you accelerate lol.
up until you destroy 5th and have to cruise in 4th or 6th.
ill iron out all the kinks of it if you like :down:
haha, its ok its meant to make all those little noises anyway its normal. i looked up supra's and they are the same and im sure bmw used the same gearbox as well.
whats your gearbox like? ive heard that evo gearbox's can be a bit notchy? dont know if its true though.
how would i destroy 5th? by the time i get to go into 5th im just cruising by then or else id be way over the speed limit. i guess at a racetrack would be different.
yeah mines good, have the 5 speed
unlike the evo 8/9 which have the 6 speed the 5s are just a little stronger
when i rode with jamie, the GTR's driveline was noisy as f**k!
i read thats normal, really makes it feel like the cars got its own soul though :)
on another note, nick you going autosalon?
thats a good point, i didnt buy it for it to be quiet and comfortable ( even though it is actually very comfortable). if i wanted that i would of got a luxury barge. i worked my ass off for this car and im happy with it :O .
i read thats normal, really makes it feel like the cars got its own soul though :O
nah dont think so man, especially that its at showgrounds... if it was at exhibition centre i would cause when i get bored i would head to crown lol
will be having more regular games at my joint now that we've finished this
ohhh tuff
what you do to make it?
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
