fucking hell.
EPA full emission and noise letter came in the fkn mail. Due Date 8th September. Sucks arse
The world seems to balance it self out, on one hand im flying business class to Ireland/Germany/Poland for work and then this EPA bullshit is due whilst im overseas.
If fail EPA test, retest fee is $39.40. No mention of fine if fail, so I guess thats okay :P
Going to write a letter and see what my options are... FML
Try to do everything by the book and an arrogant pig has to fuck it all up with a bleed valve. /Ragequit
dunno if i wanna go for this look. but possibly
18 inch Work Meister S1. Epic dish. $3300
They are 18 x 9.5" +16 and 18 x 11" +16 with 5 x 114.3 stud pattern
lol that's the sizes that's goin on my golf. meisters. with even more offset. deal w/ it.
also, if you're gonna rock epic 3pc meisters with chronic offsets, and your rim's not gonna sit less than 1cm from the fender, don't buy it. let it go to a good home instead.
it's like abandoning a puppy when it grows up cos it ain't cute anymore. furreals.
been gone 2 months and your still getting your rims, whats the go?
gettin outer barrels made. i told em it wasn't a high priority job... no rush. it doesn't need to go on till car's resprayed and panel beaten anyways.
plus the bolts haven't arrived from germany... this is due to waiting on my not so clever cousin to mail it to me.
altho now that I'm public transporting it like a peasant I might as well get it done.
LOL If your referring to me, you either hadnt seen my car with previous wheels or you dont know how I roll LOL
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
