Yeah, P's FTL. February needs to hurry the f_ck up.
I can't wait to be able to go out to dinner and have a beer, drive through a booze bus and not worry about losing my license for drink driving and high-powered vehicle :)
Yeah, mine will most likely be below legal height pretty soon :) Other than that they can't get me for much. Maybe atmo bov?
if being hardgay was a defectable offense, they'd be all over you and your car.
L's straight when I turned 16,
P's 1 week after I turned 18 as there was no slots on my birthday,
3 years later now I'm 21
Drove a N/A 4 door until it got written off about 1 year into my Ps, then drove my N/A coupe manual man I loved that thing, and now that I'm 21 and off Ps drive the GTR.. Next car will be a Evo for sure but figured I have to own a turbo skyline at some stage :)
I think that's what you'd call it. It's stock but when I got the car it was missing a hose. Pretty loud PSHH sound. So annoying.
I see.
So is your MR2 ready to come out for once or you keeping it to yourself?
I see.
:D
Still got some stuff to get done.
It's going in for some work in the next few weeks (gearbox, suspension, possibly bodykit fitment/respray) and then I'll bring it out.
Also gonna make it a bit more 'track spec' soon because I'm going to do a hill climb this year :) So got Recaros coming and a few other bits and pieces.
The old owner said he took it off for a reason. Something about the pod filter was knocking into the side of the engine bay. WTF??
what's blocking the other end?
From memory, I think it was some kind of black seal :)
Edited by jezza boii
Cool!
Did you tell the old owner he was a tool?
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
