sooo optus wanted my phone for few days and then wanted 150$ for repairing the screen - the place just outside of optus @ westfield doncaster (phone biz) wanted 99$ for a new screen which took 45 minutes..
don't know why i even pay 8$ to optus a month for insurance..
Lol josh got his $10,000 Project Mu 6 piston brakes on CR34M. Cant believe how big they are! They didnt clear the spokes on his VOLK GT-C's 19x10.5 with +12 offset.
Who is this josh you speak of and pics or it didnt happen!!!!! I want Project Mu brake set-up :D
Woo. Finally got the right tie rod for my car. Booked in on Wednesday to get it put on along with a full service and coilover fitment :) So car will soon be LOW..er.
im trying to find tie rods for my car atm :D . tried to get caster rods and all that did was get sent the wrong ones because he thought r34 gtr ones are the same as r32 and r33gtr's and to this day still doesnt believe me.
does that car ever get driven hard enough to require 10k project mu brakes? or is it just cos they look cool?
It was an na before so it had shit brakes, he is building it into a 500rwkw car so got the brakes as an upgrade from n/a ones and to be able to take the power later.
Dunno why he wants 2 fast cars. already has a 430awkw R32 gtr
got my new cluster off a forum member hear cos i was going to replace the rev tacho (mine just sits at 10k and goes spastic)
get it in the mail.. open it... and tacho is already sitting at 10k rpm.. WTF not a happy camper cost me 130 bucks too.. sent the guy a PM.. maybe ill try it on car first see what happens if not.. wtf...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
