Get 8 pots!
why?
I miss the brakes on my old Supra. Those were big mother f*ckers.
because you have to try and stop something that weighs somewhere between a skyscraper and a continent on shithouse 4 pot calipers. the only way to disspate all that heat is to have a larger rotor.
effective braking size of a supra is the same as a GTSt.
you can buy $80 adaptors that convert GTR calipers to use Supra rotors. Now that's a sweet and cheap upgrade for a skyline.
Virtually any 6cyl car can break traction in any weather. My Supra did it easily. It all comes down to the driver.
Auto is a bit harder I guess.
Stand on brakes, depress accelerator, let brakes off slightly, do skid
= profit.
I didn't have the SZ model 4 pots though :D Mine were off the RZ. Sif I'd call 4 pots "big motherf*ckers" :nyaanyaa:
You should see the pissy little ones on my Australian delivered MR2 though. I need to fix that shit BAD.
How would you know what I do? :nyaanyaa: Pretty sure track work requires good brakes.
And dude, you never know what the dickhead in front of you will do on the road!
Or when a bloody dog will run out of a house directly in front of you! That happened to me the other day. Lucky it was in the dry.
I panicked and slammed the brakes on. Bit of smoke but it stopped alright. I reckon I would have hit the stupid animal if it was wet.
Edited by jezza boii
only the 95 onwards models (SZ and RZ) came with 4 pot brakes. the ones that came before were all 2 potters. 4 pots are as big as you get on a poopra.
i honestly don't think you have any clue what you're talking about :(
ended up ordering 10 large pizzas lmao
on another note
my luck gets worse and worse with skylines
every f**kin car i see, am bet to it by a small amount of time
all the replies are "just sold it man" and "sold it yesterday"
f**k!
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
