Hmmm so lets say u want to use the mod, disconnect the ps3 from internet, play burnt game.
Then i want to play cod online so i would just, remove the mod usb thingo, connect internet, then play cod?
correct.
altho sony's got a court case where they get all the modchips to reverse engineer to find out if someone is pirating shit.
for now they can't tell.
correct.
just don't install the 3.42 update by the look
http://www.ps3-hacks.com/2010/09/06/ps3-fi...-3-42-released/
Sony has that covered man, if you do not update the firmware you cannot play any game over the internet. Its ok if you only play games single player or something but yea i mainly use it online.
you can't play online with it... you'll get bannzor'd. it's the USB dongle... I got the opensource DIY one and I'm building it myself. To un-mod it, you just pull the dongle out.
Finished DL'in Mafia II last night... gonna have to try it once I flash my dongle.
like Fevola? lulz
you been killin it with the lolworthy posts lately keep up the good work sir. :action-smiley-069:
:( i just cherry picked off shan's set up. but happy to take the credit
fark, had to wait long enough for someone take that and run with it.
eyes on the ball lads.
shit effort wasteland, i was in class when i wrote that haha
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
