mohsen was always ghey
never
on another note
bought my first deck of smokes(even though i dont smoke) and my first legal alcoholic drink the other day
feels good
Edited by GTR-boy
I can still see the top of the tyre on that car. fail.
also fail for implying that he has prematurity issues.
You're hard to please Shan :D And he's allowed to have a faggy numberplate - 320rwkw. Even more when he uses his Nos :(
no amount of power makes up for a sled that snap oversteers and rocks number plates that say "Mister Too Quick". They have nasal sprays for that shit.
That stance would be awesome if it just went down another 1.5 to 2 inches.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
