my drive ways gona be a bitch to get in and out of when i buy a skyline
"when you buy a skyline" being the key words. till you buy any car, shut the fuck up. no one cares.
got my license back. lol.
also, come company called "7digital" charged me 85c to my credit card, and then "activetrade" tried to charge $5000 to my credit card 30sec later. got a call from commonwealth bank sayin both transactions had been denied and a new card was being sent out. noice!
wierd thing is I don't use my credit card online except through paypal... they musta guessed the sequence.
2.5 hours to potential GTR. comes with cage and twin 2830's. not quite the single turbo GT35 I want, but it'll do for shits n giggles.
you're just like mohsen... except you actually BUY all the cars instead of just talk about them :D
lol this is gonna be car number 5 in my house now. fuuuck. i gotta start selling shit.
virgin-boy... wanna buy a car? cheap cheap. All turbos but, altho the ceffy is P-Plate legal as it's a turbo sedan which is exempt. comes with nut dragging low low, factory doilies and fully sick factory flutters (no recirc on intake pipe).
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
