my drive ways gona be a bitch to get in and out of when i buy a skyline
"when you buy a skyline" being the key words. till you buy any car, shut the fuck up. no one cares.
got my license back. lol.
also, come company called "7digital" charged me 85c to my credit card, and then "activetrade" tried to charge $5000 to my credit card 30sec later. got a call from commonwealth bank sayin both transactions had been denied and a new card was being sent out. noice!
wierd thing is I don't use my credit card online except through paypal... they musta guessed the sequence.
2.5 hours to potential GTR. comes with cage and twin 2830's. not quite the single turbo GT35 I want, but it'll do for shits n giggles.
you're just like mohsen... except you actually BUY all the cars instead of just talk about them :D
lol this is gonna be car number 5 in my house now. fuuuck. i gotta start selling shit.
virgin-boy... wanna buy a car? cheap cheap. All turbos but, altho the ceffy is P-Plate legal as it's a turbo sedan which is exempt. comes with nut dragging low low, factory doilies and fully sick factory flutters (no recirc on intake pipe).
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
