lol @ those leather seats, you're gonna have fun trying to keep them clean and stain free :thumbsup:
True, he'll probably lay down some skid marks when he snap oversteers in the wet or if Kris cuts him off while "cruising".
stop having boring tuna. chop chop chop chop.
Boring? I love it. Have it every day
bullshit asshole noone likes the tuna here
I do actually...
P.S I was gonna add that to my post to save everyone the hassle of posting the obvious!
sirena is best canned tuna imo
Safeway is actually the best imeo.... The only brand to use 100% olive oil and not an 'olive oil blend'. I don't do the flavored shit
new TE's look shit hot on old clunkers...
KE rolla boys, get on it now instead of trying to jump the bandwagon 3 years later.
once i get the 55 going will look into them, but may be too old to use them
salami and cheese toastie while waiting for pasta to cook. nom
salami and cheese toastie.... a maso basic food group lol
they are awesome :)
I do actually...
do they do chunks? never had safeway
sirena is wayy overpriced
they are awesome :)
yeah they do chunks, think they were on special at $1 a can last week for the small cans... Think greenseas might be on special this week, picked a fair few of em at work..
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
